Need the JTA Sensor without getStatus() method
mike_gardner
Guide
Our system uses Java EE / JPA / Hibernate. I really want to see JTA transaction begins / commits / rollbacks. Unfortunately, something in the lower tiers of the code was repeatedly calling getStatus() within the JTA sensor, and my 10,000 node limit is reached with 9,500 of the nodes being getStatus(). I had to inactivate the JTA sensor.
Is it true that I can't exclude a method from a Dynatrace-supplied sensor? Is there any way I can use the JTA sensor, but exclude the getStatus() method?
I'm running AppMon 6.5.7.
Thanks, Mike
Babar_Qayyum
DynaMight Leader
DynaMight Leader
Hello Mike,
You can exclude the getStatus(*) from the sensors pack.
Open the client in the Debug Mode (Ctrl + Alt + F9) and then select Settings > dynaTrace Server > Sensor Packs then Select the JTA Sensor Pack and Edit and drop down the Place and select the Exclude.
I hope this will be helpful for you.
Babar
Nailed it, Babar. Much appreciated! -- Mike
