No transaction flow and purepaths for system profile
rajanikanthanka
Inactive
Hello all,
I created a system profile for application and java agent. All agents are up and running but not seeing transaction flow and user action purepaths. I am including some screenshots here. Please help me what I am missing here.
Rajanikanth
4 REPLIES 4
Babar_Qayyum
DynaMight Leader
DynaMight Leader
Hello Rajanikanth,
In the same dashboard check whether you have event counts, class load count etc...
Also check the following sensors are active and start PurePaths.
For the UEM, make sure that slide bar is on the right most.
Babar
Hi Babar,
I see Event count and class load count from agents overview and they are showing values but total purepath count, cputime and execution time are zero.
I already enabled for servlets and User experience. Also enabled for Java web requests and java web services. Capturing is set to extreme right. All changes are done. But still I am not seeing any purepaths or transaction flow.
Do I need to restart my server and agents?
Hello Rajanikanth,
You can try once to restart the application to see the results. You can also share the logs after restarted the application.
If this is a non-web application or a proprietary Java Application, we may need to define your own PurePath starting points.
Check the following post to define the entry points:
https://answers.dynatrace.com/questions/108903/capturing-purepaths-in-non-web-applications.html
One more knowledge base with the screenshot examples to define the custom entry point in case of Auto Sensors are not picking up the PurePaths.
https://community.dynatrace.com/community/display/DTKB/How+to+define+entry+points
Babar
Thanks Babar. We restarted agents and it worked. Now we are seeing transaction flow. and purepaths.
Rajanikanth
