Not able to open Dynatrace Web
karthikayini_mu
Inactive
Hi All,
I could never open my web dashboards
Can any one suggest me what would be the problem.
I can never ever login to https://xxxxxxx:9911/ Dynatrace Web .
Could you please suggest me whether URL is correct.
I am using portable client from my office network.
Form there also I am not able to connect.
telnet from client not happening.
Telnet from dynatrace main server it is happening
Please suggest me.
ERROR:
PrintWindows Network Diagnostics Publisher details
Issues found
resource (XXXX) is online but isn't responding to connection attempts.resource (XXX) is online but isn't responding to connection attempts.
The remote computer isn’t responding to connections on port 9911, possibly due to firewall or security policy settings, or because it might be temporarily unavailable. Windows couldn’t find any problems with the firewall on your computer. Detected Detected
Contact the service provider or owner of the remote system for further assistance, or try again later Completed
Issues found Detection details
6 resource (XXXX) is online but isn't responding to connection attempts. Detected Detected
Detection details Expand
InformationalNetwork Diagnostics Log
File Name: D253F3A7-08FE-4D22-BEA9-4AA868C3609D.Diagnose.0.etl
InformationalOther Networking Configuration and Logs
File Name: NetworkConfiguration.cab
Collection information
Computer Name: YYYYYYY
Windows Version: 6.1
Architecture: amd64
Time: ZZZZZ
Publisher details Expand
Detects problems with network connectivity.
Package Version: 1.0
Publisher: Microsoft Windows
Thanks & regards
Karthikayini M
Babar_Qayyum
Leader
Hello Karthikayini,
First of all port # 9911 should be open from the source to the Dynatrace Server.
9911: AppMon Web to Frontend Server | Port on which browser-based dashboards get their data.
Secondly If you are trying to access over the internet then there should be a published URL to access.
Review the below link for the default communication layer used by AppMon components, and provides access to information about configuring the settings needed to deploy AppMon into a networked environment.
https://www.dynatrace.com/support/doc/appmon/insta...
Babar
