Not able to see applications in dynatrace 6.5 monitoring dashboard for one of the system profiles
svedula
Newcomer
monitoringdashboard.png Hi all, After migrating to 6.5,we were able to see list of applications and request/minute in the default monitoring dashboard but seeing a 0 in the last couple of weeks.I can still see the purepaths and host info but not the above mentioned metrics.I went to systemprofile>applications and 1.auto detected by host is checked and a list of applications are visible there.
Do you think creating user defined applications will resolve this (most of the system profiles have auto detected )and we were able to see them in monitoring dashboard or
restart the services?
Appreciate your input.
thorsten_roth
Dynatrace Pro
Dynatrace Pro
I would recommend to create a user defined application. auto detected can cause several problems (too many, not detected at all, etc.)
