Permission/Hide/Deletion of built in web dashboards
yair_mashmor
Guide
Hi all,
I would like to figure out how can i hide the built-in web dashboards (ones the Owner is Dynatrace), from other users. I know how i can do this for costume dashboards, but i cant find that option for the built-in ones.
I have checked the users roles permission in the appmon client, but there is only "View web dashboards" and a few other that dont control the viewing of the dashboards.
In addition, we have found the location of the web dashboards on the sever, but it seems like only the costume dashboards are saved.
Thank you,
Yair
5 REPLIES 5
mat_cat_adn
Advisor
Hello Yair,
You can try to clone built-in web dashboards, manage their access as custom dashboard and delete them attached to Dynatrace user.
Mathieu
Hi Mathieu,
Thanks for your answer, question here is how to not show the built in dashboards to all users.
Is there a way to delete those builtin dashboards?
Yos
dynatrace certificated professional - dynatrace primer partner - Matrix Soft Ware Division - Israel
Thanks !!!
Thank you Peter.
