Postgres connection -Monitored Technologies
kartik_kumar
Newcomer
I am trying to configure postgres inder monitored technologies where you enter global configuration for postgres.
After I enter the credentials for postgres, it shows as initializing for a while and then fails with a error, sometimes shows failed to initialize host x or sometimes shows connection problem.
Where can I see logs on the machine that can help me debug the problem ?
My logs reside under /opt/dynatrace/oneagent/log/...
This folder has many sub folders and most of the files are named as rx...
So not able to figure out which log file will give answers to m problem!
Any hint would be helpful, thanks!
mathieu_chatte1
Advisor
The log would be on the Dynatrace host (Collector or Server) where you have configure the execution of your tasks.
You can also see the log on Dynatrace Client in System Information Dashboard.
Mathieu
