Primary and secondary agents have different versions for unix agent
After installing 7.2 agents and when latest patch is applied, the primary and secondary agents are into the different versions. no matter on how I restart (as per order), it never got fixed. So, need help to resolve the issue
rodrigo_alvare1
Dynatrace Pro
Dynatrace Pro
I think you should do a apachectl stop + apachectl start ( do not use restart)
https://www.dynatrace.com/support/help/offline-doc/what-is-complete-apache-web-server-restart/
Upgrade agent info:
1) restart the Dynatrace web server service
2) restart the apache process
https://www.dynatrace.com/support/doc/appmon/installation/upgrade-and-migration-guide/upgrade-agents...
Upgrade video (min 34 he upgrade the agents)
https://university.dynatrace.com/ondemand/appmon/4...
Regards
