Problem with BT, I can't split my data by header value
d_circhirillo
Participant
I saw more thread about the BT but i have still problem with the custom BT.
I would create a BT where I can see:
  1. All the pages visited by the users (by Server-Side PurePath);
Here, the procedure followed:
  1. To retrieve the users I add the field on the webServer sensor so from purepath details now the value is present.
  2. Create the measure "Web Request - Response Header" with:
    1. Header Field -> user-logger
    2. Match -> contains
    3. Evaluation -> occurrence
I created my BT as showed below:(The complete URI Path is a default BT)
The result is nothing, i don't see any result. If I delete my measure from BT I can see all URIs into BT's table.
Could you help me to understand where I get wrong?
Thank you very much.
Davide
5 REPLIES 5
dave_mauney
Dynatrace Champion
Dynatrace Champion
Hi Davide,
I have done this many times with Request Headers but not with Response Headers. Is your header really a Response Header? If not, try using "Web Requests - Header Value" when you define it rather than "Web Requests - Response Header Value".
HTH,
dave
Hi Dave,
Thanks you very much, unfortunately also setting web Requests as you advice me didn't work.
I add also this detail:
Is it correct for you?
Davide
dave_mauney
Dynatrace Champion
Dynatrace Champion
Hi Davide,
Please change Evaluation to "string value" rather than "occurrence".
HTH,
dave
dave_mauney
Dynatrace Champion
Dynatrace Champion
Also, there is no need for a threshold since this is a split measure, not a filter...
d_circhirillo
Participant
Hi Dave,
Thank you very much for your support. I resolved as you suggested me.
Davide
