Problem with filtering several PurePaths at tha sema time
xhernandez
Newcomer
I have problems for several PurePaths at the same time.
I want to create a Dashboard by filtering several PurePaths.
I only see the way to filter a PurePaths (Edit Filter -> PurePaths -> Name PurePaths)
Does anyone know any way to filter several PurePaths at the same time?
I have the version dynatrace appmon 7.0.0.2469
Babar_Qayyum
Leader
Hello @Xochitl H.
The filters provided by the AppMon Client are generally designed to filter out the underlying PurePaths. That means filter settings are not applied on visible data in views but instead are applied on the underlying PurePaths. The only exception is the Top X filter, which is exclusively applied on the visible data.
In the below link you can see the example to filter the PurePaths with the API breakdown.
https://www.dynatrace.com/support/doc/appmon/appli...
Babar
