Query regarding Docker-Appmon instrumentation and help needed over a issue
sanjay_lall
Newcomer
Hi Team -
We have a appmon setup with 2 agent license. We want to monitor a Linux VM having docker containers running with them. Can i setup a agent at OS level and configure the agent path to the container , will i be able to monitor the docker containers and transactions. Its Java based. Also for a try i started with installing a agent in my VM from the below github link-
https://github.com/Dynatrace/Dynatrace-AppMon-Docker/tree/master/Dynatrace-Agent
and when trying to use docker-compose i hit a blocker at line :
fetch http://dl-cdn.alpinelinux.org/alpine/v3.5/main/x86_64/APKINDEX.tar.gz .
This gives network error (check Internet connection and firewall) and i believe i have limited access to the internet. But using wget i could download the zip file though. Any idea how can i overcome this issue and build the container .
Note: my firewalld service at VM is disabled but i have firewall controlled from my datacenter. As per datacenter support team i am allowed to use curl / wget.
amlan_s_das
Newcomer
Any help on this is very much appreciated?
