Rabbit MQ Monitor Plugin for AppMon
ilyas_ekmekci
Newcomer
I have a question about the
Rabbit MQ Monitor Plugin which version is 6.2.2.5. I did all of the
plugin configuration on AppMon Server include schedule RabbitMQ Monitor. But
when ı tried to get meauseres that Messages Ready and Messages from RabbitMQ
via rest api, it didn’t work. Only I receved “null” every time. I guess the
Rabbit MQ Monitor Plugin for AppMon didn’t work as expected. So how can I fix
it ? Do you have any suggestion ?
Best Regards.
Özgür
İlyas Ekmekci
4 REPLIES 4
rodrigo_alvare1
Dynatrace Pro
Dynatrace Pro
Hello Ozgur,
Have you verified that the Rabbit MQ is reachable from AppMon collector where you are running the plugin?
Also you could check the logs to find more information about why the call is failing.
Regards
ilyas_ekmekci
Newcomer
Hello Rodrigo,
I can confirm that Rabbit MQ is reachable from AppMon because when I tried to get the other measures which, came from default plugin, they did well. If I create specific measure for only one queue, It returns "null" value. I configured AppMon's Rabbit MQ Plugin exactly as mentioned in this link "https://community.dynatrace.com/community/display/... I attached my screen shot.
Thank you for helping.
clayton_swiggs
Participant
Hi Ozgur E, did you ever get to the bottom of this issue? I have the exact same problem. Just wondering if you found the cause of the issue?
ilyas_ekmekci
Newcomer
Hello, unfortunately I haven't resolved the problem. Rabbit MQ Monitor Plugin for AppMon hasn't any support from Dynatrace. I hope you will find the solution.
