Rabbit MQ Monitor Plugin with RabbitMQ installed in Pivotal Cloud Foundry
christian_becke
Newcomer
we would like to use the Rabbit MQ Monitoring Plugin with our Rabbit MQ instances deployed in the Pivotal Cloud Foundry. But the measure for the free disk space doesn't work and shows no results in the dashboard.
The API from the RabbitMQ shows the correct values but we weren't able to get it right in the measures in the dashboard.
Question is
  • How do we get the values right in the Dashboard for the disk space ?
Kind regards,
Christian
birtan_ozel
Inactive
Hi Christian,
Can you send me the API overview output as a text file? It would make it easier to check, why it doesnt work with the plugin.
Birtan
