Regex Question
ajdimanuel
Inactive
I am trying to get from URI's first and second directories, not files but I dont get it. For example, from the following URI /Content/Images/li-deco.jpg y want to extract /Content/Images/. Could you help me?
Thanks in advance.
Alberto.
christoph_wiesi
Dynatrace Helper
Dynatrace Helper
Hi Alberto,
the regex
should work.
Best Regards,
Christoph
ajdimanuel
Inactive
Thank you. It works.
Alberto.
