Sensor configuration is not working for method
sponnada2
Organizer
Hi All,
We have placed sensor on one method and enabled all sensor packs at agent group name level but its not getting data in purepath details.
Can anyone provide suggestion?
Shyamala
sebastian_kryst
DynaMight Leader
DynaMight Leader
Enabling all sensor packs without consideration of implications isn’t good idea. Some of sensors are heavy and may produce overhead. But some of the sensor, especially custom ones needs hot sensor placement for java (agent overview and right click on agent you need, pick hot sensor placement)z .net agents need to be restarted (for example iis recycle, .net service restart).
If your process is custom one (for example .net service) you have to create special sensors called entry points. There are the ones that are starting point for transactions.
https://www.dynatrace.com/support/doc/appmon/shortlink/id_sensors#entry-points
hi Sebastian,
We have created custom one but this service having entry points calling from mobile app which don't have dynatrace on it.then how can we sort out this issue?
