Speed index for UEM useractions is not displayed for Dynatrace 7.0
sponnada2
Organizer
HI,
Recently we have upgaraded to Dynatrace 7.0.after upgrdation we are not able to see speed index for user actions.I have found one post for speed index.below is the link
https://www.dynatrace.com/blog/optimize-user-exper...
I am able to navigate to Application through Navigation bar but i don't see any settings over there.Could anyone please tell me how to navigate Settings in
particular application
7 REPLIES 7
JamesKitson
Dynatrace Leader
Dynatrace Leader
It sounds like you are using AppMon 7 not Dynatrace which the steps in that blog post are referring to. For AppMon you can enable that within the user experience settings for the application within that system profile.
https://www.dynatrace.com/support/doc/appmon/user-experience-management/how-does-uem-work/visually-complete/
James
sponnada2
Organizer
HI James,
thanks for response!!!
we have already check visually complete check box but still not able to see.
Be aware that it is not supported on all browsers/devices. You can refer to this post for a bit more information: https://answers.dynatrace.com/spaces/148/uem-open-q-a_2/questions/187775/visually-complete-compatibility-and-supported-brow.html
sponnada2
Organizer
HI James,
We are able to get visually complete in useractions but we are not getting speed index
Hello Shyamala,
I just wanted to add that the 'Speed Index is only available for page load actions'.
Have a look on the following link:
Babar
sponnada2
Organizer
HI Babar,
We are having UEM and not able to see speed index for page load actions.
shyamala
syed_hashmi
Newcomer
Hi Shyamala,
Under newer DT AppMon versions Speed Index is mentioned seperately rather it's subset of Visually Complete option.
There could be a possibility that SI is disabled, please try the following and check if the issue still persist.
1. Disable (Uncheck) Visually Complete
2. Save the System Profile
3. Enable (Check) Visually Complete
4. Save the System Profile
This doesn't require any restarts.
Thanks & Regards,
Uzair
