Transaction flow domainless unknown host ?
ssakiz
Newcomer
We have an external host in domainless group as "unknown host"
How can we replace "unknown host" with an IP:PORT or dns name + port information ??
Here are the steps that we have followed;
- Focus on passing transactions on unknown host.
- Go to pure paths sort by arguments.
- We know that our java application in test_jvm is using Ca api and custom TCP protocol and making socket calls.
- We can see the socket calls but we can not see the IP & port informationç
We want to see real IP port info instead of unknown host ??
Thanks.
brian_thong1
Newcomer
Hi Semih,
Any chance that your Dynatrace version is running on 7.1.11.1011?
We are also facing similar issue with one of our client's environment (Dynatrace 7.1.11.1011). External service calls are appearing as unknown hosts instead of IP address.
However, in another client's environment (Dynatrace 7.1.16.1008), we are able to view external service calls as IP address.
Is this possibly a product issue which can be mitigated by patching to a certain version of Dynatrace 7.1.16.xxxx?
Or did you manage to tweak some configuration for external service calls to appear as IP address? Appreciate if you could share the workaround if available.
Brian
