UEM consumption in an hybrid application
cortega
Participant
We are instrumenting an hybrid application and we need to know the uem consumption each visit.
There is any difference between having an hybrid application making calls to a rest api or having a hybrid application taking html content from the web server?
Carlos O.
3 REPLIES 3
dominik_punz
Dynatrace Pro
Dynatrace Pro
There is no difference whether html is bundled in your app or loaded from a web server. I hybrid environments the data captured by the JS agent and the data captured by the mobile agent are both combined into a single visit and therefore only a single visit is consumed from your license.
Thanks for your answer.
Babar_Qayyum
Leader
Hello Carlos,
Technically only one visit should be count/consume but there are many other factors to deduct the visit from the volume e.g. A visit can't cross applications. Applications and visits are a one to one mapping. So if you have two applications defined by URL-pattern and your customer accesses both, it results in two visits, even if it was without a timeout.
Have a look on the below link for more information.
https://www.dynatrace.com/support/doc/appmon/insta...
Babar
