Unable to split Traffic Lights by host in Dynatrace Appmon Web
apadmana
Newcomer
In Appmon 7 Web, while creating dashboard for CPU using Traffic Light tile, graph is not getting split by host. dynatrace.jpg
trevor_masseng1
Dynatrace Pro
Dynatrace Pro
Notice that underneath "cpu" and above the green check mark on the left it says "Maximum of 1 series exceeded".
This is because in the web dashboard you can only select one splitting or series per Traffic Light tile, or in other words it won't put more than one traffic light in a tile.
You'll have to create a traffic light tile and only include one agent host under the Selected field, then repeat the process.
I hope that helps.
