Updated Generic TCP Monitor Plugin
jomclaughlin
Participant
Is there a newer Generic TCP Monitor Plugin compatible with AppMon 6.5?
4 REPLIES 4
Ingo_Hackl
Dynatrace Advisor
Dynatrace Advisor
Hi John,
please try this version
https://github.com/Dynatrace/Dynatrace-TCP-Port-Mo...
It should also work with AppMon 6.5
Ingo
jomclaughlin
Participant
That's the version I was informed to remove due to being incompatible with 6.5
gabriel_casella
Dynatrace Pro
Dynatrace Pro
John,
I've updated the plugin to make it work with AppMon 6.5. You can download it here:
https://github.com/gbc921/Dynatrace-TCP-Port-Monit...
Please let me know if something goes wrong.
PS.: This version will be available at the official page at some point, while this doesn't happen, just use the one from above.
jomclaughlin
Participant
Thanks! I will give this a shot
