Using CPU measure in Business transaction filtering
Dear community, I was not able to find a solution for this?
When defining a BT filter only transaction based measures are offered to use.
Is there some way how to do iT?
sebastian_kryst
DynaMight Leader
DynaMight Leader
Business transactions by it's definition are transaction / visits based entities. What is your case in general. What do you want to do 🙂
I would like to filter particular measure threshold trigger - so the threshold would be active only when CPU load is lower than let us say 15 percent. Cause when there is higher load the response times go high too and it triggers false alarms.
