Warning TimeKeeper logs problems
asruinoiua1
Newcomer
My Dynatrace server have some logs in Server.0.0.txt:
2017-04-01 21:24:03 WARNING [TimeKeeper] Skipping from 1491056600000 to 1491056620000 (20000), incident resolution might be lower than expected. Skip Count is 128. [log message will be suppressed for 30 minutes]
I do not understand, please tell me the meaning of these logs. It is a error, isn't it?
Thank you very much.
andreas_grabner
Dynatrace Leader
Dynatrace Leader
Hi Duta
I suggest to open a support ticket for this so that our tech support engineers can look into your log files and tell you what might causes this issue
In case you get an answer it would be great if you could share it with the community
Andi
