Web requests not related to JQuery Ajax calls
antonio_castro
Participant
I have a SPA framework app that uses JQuery Ajax to make WebAPI calls. I see the web requests in Dynatrace for those calls but they do not have a jquery call associated with them. They just show up as web requests in the visit. I have the following UEM configuration:
Why would this not show up as a jquery call? UEM does report on user actions otherwise.
Tony
andreas_grabner
Dynatrace Leader
Dynatrace Leader
Thats a good question. Normally we should pick up user actions triggered by jQuery.
We do have some "advanced" options that are available in the UEM configuration if you bring your Dynatrace Client to debug mode (Ctrl-Shift-F9). There is an option to say "click event handler" -> which means we capture every click event handler that we are currently not capturing through our JavaScript library support. You could give this option a try and see if it solves your problem
If you are sure though that these calls are done through jQuery then you might also want to open a support ticket. Maybe you are using a jQuery version that we are currently not supporting. Could also be that your version is supported by a later version of AppMon -> these would be things that our support team could tell you
Andi
