What is "Max System"?
jgarcianar
Contributor
What's "Max System"? Why should it be so low? See attached snapshot.
Thanx.
BR,
Juan
Mike_L
Dynatrace Pro
Dynatrace Pro
Max System is related to System CPU time. When you execute a program it does most of its work in User CPU time, while whenever it requires something from the OS (kernel) it is registered as System CPU time. A high System CPU time can be caused by things like I/O issues or an application that uses the system inefficiently by, for example, asking the OS for the resource usage of all processes once every millisecond.
Mike
jgarcianar
Contributor
Thanks for the info, Michael L., it's going to be very useful for us.
BR,
Juan
