What is the best way to execute a shell script on mulitple unix hosts and return results to appmon
clayton_swiggs
Participant
We are in the process of migrating host monitoring of our Unix hosts from
Nagios into Dynatrace. I have been investigating one particular migration issue
where we are trying to find a way to execute the below shell script across more
than 100 aix hosts and have the results returned to Dynatrace so we can perform
alerting.
I installed the Generic Execution Plugin from the community but we are
unable to access these aix hosts via direct ssh during to security policies. Do
you have any suggestions about how else we can do this, either via the local
access method of the GE plugin or possibly by executing a cron on the remote
hosts to run the script and then somehow send/retrieve the results in Dynatrace?
AIX mpath shell script:
#!usrbinksh
#set -x
# $Id check_mpath.sh 145 2012-09-16 125628Z
u09422fra $
# AIX multipath check plugin for Nagios
# Paths
EGREP=usrbinegrep
LSPATH=usrsbinlspath
TR=usrbintr
WC=usrbinwc
# Nagios return codes and strings
R_OK=0;S_OK=OK
R_WARNING=1;S_WARNING=WARNING
R_CRITICAL=2; S_CRITICAL=CRITICAL
R_UNKNOWN=3;S_UNKNOWN=UNKNOWN
S_ALL=
# Variables
PATHS_TOTAL=0
PATHS_ENABLED=0
PATHS_NOT_ENABLED=0
# Check for lspath executeable
if [ -e ${LSPATH} -a -x ${LSPATH} ]; then
PATHS_TOTAL=`${LSPATH}${EGREP}
-vi ses${WC} -l${TR} -d ' '`
PATHS_NOT_ENABLED=`${LSPATH}${EGREP} -vi ses${EGREP} -vi
enabled${WC} -l${TR} -d ' '`
if [
${PATHS_TOTAL} !=-a ${PATHS_NOT_ENABLED}
!=]; then
PATHS_ENABLED=$((PATHS_TOTAL-PATHS_NOT_ENABLED))
S_ALL=Paths total(${PATHS_TOTAL})enabled(${PATHS_ENABLED})not
enabled(${PATHS_NOT_ENABLED})
else
echo
MPATH ${S_UNKNOWN} - Unknown value ${PATHS_TOTAL}, ${PATHS_NOT_ENABLED}
exit
${R_UNKNOWN}
fi
if [
${PATHS_NOT_ENABLED} -gt $((PATHS_TOTAL2)) ]; then
echo
MPATH ${S_CRITICAL} - ${S_ALL}
exit
${R_CRITICAL}
elif [
${PATHS_NOT_ENABLED} -gt 0 ]; then
echo
MPATH ${S_WARNING} - ${S_ALL}
exit
${R_WARNING}
else
echo
MPATH ${S_OK} - ${S_ALL}
exit
${R_OK}
fi
else
echo
MPATH ${S_UNKNOWN} - lspath not found or not executeable.
exit
${R_UNKNOWN}
fi
exit 0
## EOF
sooryaprabha_mo
Inactive
Just try to execute the GEP as a monitors and run manually to check AIX server is reachable from dynatrace.
Usually GEP runs in dynatrace Collector, so from communication between dynatrace collector and all AIX servers should be present.
Also dynatrace collector should run on the account which has rights to access Remote connection to AIX servers. In case if you are executing Scripts which is placed in some destination(this path must have access to the account(dynatrace collector runs)).
Please walk through below link, hope it will be helpful
https://answers.dynatrace.com/questions/90387/exec...
Soorya Mohan
Joe_Hoffman
Dynatrace Champion
Dynatrace Champion
Clayton,
The Generic Execution Plugin is open source, so you're free to modify/augment it as necessary to communicate to your AIX hosts in whatever manner and protocol your infrastructure permits.
An alternate idea: Run your chron job idea to generate the required data, push that data to a file system that's accessible to a Dynatrace Monitor. Then write a Dynatrace Monitor to read that file system (using local mount, HTTP, FTP, whatever) and populate the measures that trigger the incidents. Use the Generic Execution Plugin source as a reference and I think you'll find writing plugins is quite easy.
