What is the difference between AppMon Self-Monitoring and Monitoring
szxhchen
Participant
After upgrading from 6.2 to 6.5, something changes. What is the difference between AppMon Self-Monitoring and Monitoring in the Incident Dashboard? Please see the screenshot
bellow.
6 REPLIES 6
szxhchen
Participant
what is the difference bwtween TI DYNATRACE ,dynaTrace Self-Monitoring and Monitoring in the built-in Dashboard Incident?
Babar_Qayyum
DynaMight Leader
DynaMight Leader
Hello Xiaohe,
Monitoring is a default systems profile which is created with the server installation so you can use the same profile to configure your environment.
Self-Monitoring is to check the health status of DynaTrace Server. You can have a looking on the following link for more information.
https://community.dynatrace.com/community/display/...
Babar
joe_wells
Participant
Hi @Babar Q.,
With this in mind, am i able to remove the "Monitoring" profile? or will this cause an issue
Thank you
Joe
Babar_Qayyum
DynaMight Leader
DynaMight Leader
Hello Joe,
Unfortunately you can not delete the 'Monitoring' system profile :).
Babar
joe_wells
Participant
ah, fair enough, thanks for comming back to me so quikcly
Babar_Qayyum
DynaMight Leader
DynaMight Leader
Hello Joe,
Apologies for me last answer.
You can remove the 'Monitoring' system profile in the client 'DEBUG' mode (Ctrl + Shift + F9) but I believe there is no harm if it keeps sitting there, otherwise simply disable it if you really don't like :).
Babar
