What is the difference between Max and Last in aggregation. ? Please explain with example.!
ajay_kumar
Newcomer
4 REPLIES 4
peter_karlhuber
Dynatrace Pro
Dynatrace Pro
Imagine that you're measuring the disk utilization (in %) of a host. You get these measurements:
08:13 ............. 13%
08:15 .............. 15%
08:17 ............... 75%
08:23 ................. 93%
08:56 .................. 20%
In this example, the aggregations for the hour between 08:00 and 09:00 are
min ..... 13%
max ...... 93%
last ...... 20%
avg ....... 42.2 % (although probably pointless in this case)
sum ...... pointless
note that not all the aggregations are useful for all the different measures.
ajay_kumar
Newcomer
@Peter K.
Thanks for the explanation.
Attached incident created on based on JVM memory utilization.
Please suggest what value should i use for :
1 Check for every 15min
2 Threshold 92%
3 Alert should be sent whenever JVM Memory exceeds 92%.
Ajay
In this case you want to use the maximum aggregation.
Thanks.. !
