What is the difference between Rich Client and Portable Client
karthikayini_mu
Inactive
Hi All,
I am using Portable Client. What is the difference between Rich Client and Portable Client.
Am I loosing any feature as I use only portable Client.
Thanks & regards
Karthikayini M
6 REPLIES 6
BabarQayyum
Leader
Hello Karthikayini,
Portable Client, that you don't need to install and Rich Client, you will have to install before using.
Secondly, you can access more than 1 Dynatrace Server with the Rich Client but with Portable Client only 1.
You can read more from the below links.
https://www.dynatrace.com/support/doc/appmon/appli...
https://www.dynatrace.com/support/doc/appmon/insta...
Babar
Babar I think portable client will work for multiple servers as well. I think you thought about WebStart client which is starting from particular server and than it works only with that one.
Hello @sebastian k.
You are right. I mixed two things 🙂
Babar
Hi @Babar Q.
Thanks a lot for the reply.
I have read both. Hope I am not loosing any kind of extra features by using portable client.
Drill down features and all cockpit properties are same.
Thanks & regards
Karthikayini M
Features are the same between all clients (Portable/Installed/Webstart). Only thing you miss in webstart is accessing multiple servers, as mentioned above.
From experience, I can say that a rich client works better with large analyzes where it may be necessary to increase the allocated RAM for client.
