What is the difference between setting up measures using Weblogic Monitor plugin OR using Agent based measures in server side performance for weblogic?
ravneet_gill
Guide
I would really appreciate any help on this because I find it the same if I already have an agent installed. Do we still need to use Weblogic monitor in system profile - monitors for any reason?
david_n
Inactive
Hello Ravneet,
The monitor plugin would be used if you were not able to install an agent on the server running Weblogic. The plugin could be run from the collector as long as it had firewall access to the server. The disadvantage would be that you would loose all your other deep dive details. Since you have the agent installed, the best approach would be to use the measures on the agent.
David Nicholls
thank you David for confirming this. Appreciate your help on this.
