When configuring Mobile monitoring what does "DTXAgentStartupPath" mean?
bcox2
Organizer
Does this step refer to the applcations web server that is instrumented?
Add the key DTXAgentStartupPath to your Info.plist file. Its value is your instrumented web server. For example http(s)://<myWebServer>:<my port>.
Wnated to make sure we have all pieces set before we try to test mobile adk?
Brian
BabarQayyum
Leader
Hello Brian,
Your understanding is correct. We use this key while Auto-Instrumentation for iOS instruments and the below statement is for better understanding about.
If this key is present with a valid value, the Mobile Agent starts automatically and using this value as the serverUrl name. It ignores any manual startupWithApplicationName calls in your app. serverUrl must start with the transport mechanism to use (http://or https://). If it is not present, you must make a manual call to startupWithApplicationName to start the Mobile Agent.
Babar
