When will Apache and Java OneAgent be supported on Solaris SPARC and Linux PPC ?
The_AM
Dynatrace Pro
Dynatrace Pro
We have new programming technologies (for example Angular 2, 4+) being deployed across Solaris and Linux environments. With the new OneAgent for AppMon architecture, when will the support for these technologies be available?
We would like to be able to capture UEM data.
Andrew M.
4 REPLIES 4
miguel_balsa
Dynatrace Mentor
Dynatrace Mentor
Hi @Andrew M.,
Currently the Apache and Java agents for Solaris SPARC and AIX PPC are not available, but will be in future releases.There is not a fixed date for it though.
You can test the status of the One Agent releases here:
https://www.dynatrace.com/support/doc/appmon/application-monitoring/agents/oneagent/
Thanks. For all interested, the updated support list for the current and future release is on this page:
https://www.dynatrace.com/support/doc/appmon/application-monitoring/agents/agent-platform/?appmon-agent-availability=appmon-2018-april
Andrew M.
Joe_Hoffman
Dynatrace Champion
Dynatrace Champion
Andrew, I suggest you work with your Dynatrace Sales Rep to determine more customized answers to these types of questions, including possible early access to Beta versions of these types of products.
Thanks Joseph.
Andrew M.
