Where is First Party content load time metric ?
external_z10mch
Newcomer
As CDN content load time and Third Party content load time.
Thanks in advance.
5 REPLIES 5
BabarQayyum
Leader
Hello Mathieu,
Below links for the content load time.
CDN Content Load Time:
https://community.dynatrace.com/community/display/...
Third Party Content Load Time:
Babar
external_z10mch
Newcomer
Thanks Babar.
But in AppMon 6.5, we have now the First Party option (with CDN and Third Party) but no metric on it.
And i need this metric to follow performance static content served by the same domain of application.
Hello Mathieu,
The below description from the document:
The JavaScript Agent detects CDN content the same way as it detects third-party content. However, you can map certain domains captured by the JavaScript agent to CDN instead of third party or first party for either all applications or specific applications in a System Profile.
I could not find the specific metrics about first party content.
Babar
JamesKitson
Dynatrace Leader
Dynatrace Leader
The first party information is really determined the same way as third party and so you should be able to create your own instance of the third party measures that are restricted to your first party domain, and then just name the new measures accordingly as being first party content:
There may be a first party measure specifically added in the future but this should work for your purposes.
James
external_z10mch
Newcomer
Thanks James.
But it doesn't work. It was my old metric that i used.
So I found a way by creating a BT filter metric on all type of our statics and create a BT per User Action filtered on it.
I hope the first party measure will be added soon.
Mathieu
