WildFly : Monitor undertow / XNIO usage
n_sonnier
Participant
Do you know if it is possible to monitor the Http connection Usage on WildFly10 ?
Thank you,
Nicolas.
n_sonnier
Participant
I finally found a way:
  • create a new mesure: Custom JMX Measure
  • Click on Browse Metrics
  • Select a Java Agent
  • Choose the ConnectionCount Metric in Xnio/nio/default/0.0.0.0:8080 (exemple)
