appmon : how to create an incident for method level measure split by application?
satish_a_prasad
Organizer
I have a method level measure that measures response time, and splits it internally by agents and application.
How do i configure an incident that an alert should be raised ONLY WHEN a specific application-split-measure-threshhold is violated? I don't see any option in the Incident creation dialogs (appmon 7.2). If I "edit" the measure, then it basically edits the global measure.
Please don't tell me to create a new measure just for this..
5 REPLIES 5
sebastian_kryst
But creating measure is only option for me to do such task 🙂
Regards, Sebastian
Hi Sebastian.. i meant i already have a measure.. how do i configure the incident to use the application-split value for the threshold evaluation?
We opened a support ticket for this some time ago. Basically, the answer came back as create a new measure.
Doesn't seem like there is an option to restrict incidents to a specific splitting.
thanks Mike.. is there an RFE for this?
We didn't submit one. Either we created the individual measures or learned to live with the way it was designed.
