dynaTrace Client 6.2 - Application Overview Dashboard NOT visible
mzamora
Organizer
dtclient62.jpgHi, I just upgraded to dT 6.2 and the client a well has been upgraded.
I can't find the Application Overview Dashboard anymore.
I go to the Monitoring tab, then select my System Profile and all I see is the transaction flow dashboard. It does not seem like I have an option to see the Application Overview Dashboard where I used to be able to see my business transactions with baselines.
Can someone tell me what I'm doing wrong?
Alejandro_soto
Inactive
Hi Melanie,
The Application Overview Dashboard can be accessed by clicking in the bottom of the screen where it says 'Applications'
From that dashboard you can see the Health overview for each of your Applications with your BTs and baselines.
Best,
Alex.
mzamora
Organizer
Thank you! Not sure how I missed that. I guess I was used to it showing by default in dT 5.6.
