how can i check from Dynatrace side to how many HTTP Posts were done to particular request in the last two days
sarath_koduru
Inactive
9 REPLIES 9
wolfgang_beer
Dynatrace Champion
Dynatrace Champion
Can you give me some context on what exactly is your use-case here? Do you mean incoming API POST requests to Dynatrace or is this question related to monitoring your own requests?
Thanks for reply.
That mean Incoming API posts for particular request.
If possible it would be great if you filter on the form post
data:
Example:
form posts to: https://www.facebook.com/pages/
If the filtering is not possible can we do an export of all
the requests including post data into excel?
this question related to monitor own requests.
Hi Wolfgang,
Thank you very much.
JamesKitson
Dynatrace Leader
Dynatrace Leader
I think using the top web requests diagnostic tool with the applicable filters applied would give you that information:
can you please provide the info or path for how to create the dashboard?
You don't need to create anything, just navigate to it:
Hi James,
thank you very much..
You can always create multidimensional view on service page. There you will be able to filter requests by URI and method.
