how to create an incident rule for default measure
lakkireddy_lava
Participant
Kodai_Ishikawa
Dynatrace Helper
Dynatrace Helper
Hi Lavanya,
In the tool, you can create Incident Rules for default and custom measures with the same steps. The documentation steps through all of the different configuration options that are available when configuring an Incident Rule.
https://www.dynatrace.com/support/doc/appmon/appli...
Keep in mind that if you apply a threshold on a default measure, that threshold will be applied across the whole System Profile. It is usually recommended that a custom measure is created based off of a default measure to be used in an Incident Rule.
I hope that helps!
Kodai
