how to enable debug mode for Java agent for DT6.2
Hany_Abadir
Participant
We are having some issues with Java agent installation in one of the applications and the JVM is taking more than 10 minutes to start for the first time after the agent installation so I want to enable debugging or increase the logging to get more information.
Babar_Qayyum
DynaMight Leader
DynaMight Leader
Hello Hany,
Press Ctrl + Shift + F9 on the client to get into the debug mode then double click on your profile to open then select the desired tier and then agent mapping then choose the agent and in the bottom you will find the debug and then you can put the debug flags.
If I am not wrong.
Regards
Babar
