how to enable sql execution plan. DB used is MSSQL
rashmi_v
Inactive
Can someone please help me how to enable the SQL execution plan. we are using MSSQL DB, but the sql execution plan option is disabled.
Is there any settings or configurations to be made in order to see the execution plan?
Regards
Rashmi
kristof_renders
Dynatrace Pro
Dynatrace Pro
Hi Rashmi,
For the SQL Execution Plan you need to have our DB agent.
For more information on the DB agent, please check the documentation: https://www.dynatrace.com/support/doc/appmon/datab...
Hope this helps.
KR,
Kristof
Cant we achieve this without the DB agent?
