how to monitor specific Process availability Alerts in incident dashboard
pkharbanda
Contributor
test.pngI am trying to monitor processes like w3wp or any other process on a box which is dynatrace agent...is there a way I can monitor specific process up or down status in incident ...I found one option under hostgroup attached document but doesnt seem to be working as I stopped the process but no alert triggered in incident dashboard for the same. @Shane K. any directions Shane
JamesKitson
Dynatrace Leader
Dynatrace Leader
Those process availability checks/alerts in your screenshots will only work for host monitoring agents not for application agents such as Java, .NET, etc...
In your case if you are using application level agents you can really only use the built in incidents Application Process Unavailable (unexpected) and/or Application Process Unavailable (shutdown) to see when one of the processes the agent is injected into goes offline. Apart from that you can look at some of the plugins that exist that may be able to help a bit.
James
