merge several system profiles into single web dashboard
Thomas_Schmitt
Participant
Actually we have probelm to show in one dashboard data of different system profiles. We would like to do that as our design of dashboard is similar for all application of our portal.
Is there a way to handle different data of different system profiles insigth of one web dashboard?
4 REPLIES 4
Hi Thomas,
this is not possible at the moment, but we will deliver a 7+ update coming End of August that will contain this feature alongside others. Please refer to https://answers.dynatrace.com/idea/132999/planned-... for more on that.
Peter
kenneth_lynch
Inactive
does anyone know if this feature was included in the update 7.0.7.1013
Hi Ken,
this was introduced with update 7.0.6. This is the way to select a system profile per tile:
First, when a measure is selected, click advanced settings
Then select your system profile
Yes we are on 7.0.7 and able to create it.
