monitor webservices that are invoking using SOAP UI
is there anyway that i can monitor the services that are calling thru SOAP UI from dynatrace. if so, will anyone please point me in right direction
JamesKitson
Dynatrace Leader
Dynatrace Leader
Have you checked the web services dashlet? If the services are hosted on an instrumented application server you should see the calls show up there assuming they use everything standard.
https://www.dynatrace.com/support/doc/appmon/appli...
James
