"Message Flow Statistics Monitoring Plugin" using ?
amohsen
Inactive
Hi @Joshua R.,
Did you use the "Message Flow Statistics Monitoring Plugin" to read statistics information from WebSphere MQ for IBM i , similar AS/400.
Please advise if you can help.
Regards
AbdelMohsen
amohsen
Inactive
Hi @Asad A.
Are this plugin support to read statistic information from WebSphere MQ for IBM i ?, and if YES it's get same measures.
Regards
AbdelMohsen
