unable to understand leak analysis in a proper way
viswanadham_adu
Contributor
I have leak memory snap shot with me.But i am unable to understand it properly.I am unable to find what is the end class or instance that is referring a particular instance.And also i do not understand difference between referrer and referre it is confusing to me.From the leak snapshot i am able to find objects which are causing the leak but not the actual classes.For instance from attached screenshot does Historydetailctrl class holds instance Defaultctrldef or vice versa?
And also can some one explain me difference between referrers and referres with some examples?
Is it possible to share here exported memory dump as dts session or not?
Generaly here is answer to your question about how to look at it:
https://www.dynatrace.com/support/doc/appmon/appli...
