visual studio 2017 appmon plugin not working for my unit test/functional test
gopalspurohit
Newcomer
I am trying to integrate latest version of Visual studio 2017 with latest dT appmon Visual studio plugin for 7.0.
Downloaded sample app from Microsoft (eShoponWeb). Application is running without Appmon launch option i.e. while run it with IIS express option.
All the Installation/Config/ setup is completed with DT Visual studio plugin configs with dT server,port etc. However When trying to run the application from Visual studio IDE > Tools> Launch with appmon See following error
1. >> Unable to launch project, unsupported project type
Also while trying to run test with appmon for Functional,Integration,UnitTests etc again its failing with following error.(Note: without dynatrace launch
2>> 1. Could not launch application with dynatrace support :
The system cannot find the file specified
Application : \mstest.exe
Argument:/noresults/resultfile:"C:\GP\eShopOnWeb-master\Test\FunctionalTestbin\Release\appmon.test_result.trx"/testcontainer:"
C:\GP\eShopOnWeb-master\tests\FunctionalTestsbin\Release\"
3. Object reference not set to an instance of an object.
Please advise to resolve this issue..
dominik_punz
Dynatrace Pro
Dynatrace Pro
Hello Gopal,
currently .NET core projects are not supported by the plugin. We will take a look if we can support it in the future.
Dominik
