Automations
Allow outbound connection
Itani_ML
Participant
Hi, I am using the workflow to try and to access and end point with this format: https://b****.d***.co.za but it says the "host not in allowlist". Tried adding the host but it still did not work and the ip states that it not valid and the format is: 172.**.7.*6**. Is it possible to add the above endpoint 'outbound connection'?
dannemca
Did you tried to disable the Limit Outbound just to check if the endpoint is reachable?
It should work fine once you add the full host "b****.d***.co.za" to the list anyway.
