18 Jul 2025 03:15 PM
I'm experiencing an issue deploying the EasyTravel environment via Docker on an EC2 instance (Amazon Linux).
All services start correctly with docker compose up, and the containers (frontend on ports :80, :8080, and :9079) are accessible. Data is successfully reported to Dynatrace.
However, the loadgen container consistently fails to start with the following error:
This is blocking me because it doesn't generate problems. What modification can be made to correct this and simulate problems?
