30 Jan 2025 08:43 AM
I'm setting up a Jira connection at my customer, and am running into an issue with the length of the webhookurl.
I can create a "fake" connection definition when I use a short URL, but as soon as I paste the atlassian webhook URL that is generated for my project, I get an error indicating: "Name has to be between 1 and 50 characters long".
At first I thought this was just a UI bug, but also the API returns this message as soon as the URL exceeds 50 chars.
Is there any way currently I can push my definition without getting this check/error? Because I cannot change the webhook URL delivered by Atlassian-Jira.
Thanks!
Sjoerd
PS. the fact that the message is "Name..." instead of "URL...." makes me wonder if it is not just a very simple bug in assigning checkrules to api fields
"error": {
"code": 400,
"message": "Constraints violated.",
"constraintViolations": [
"path": "app:dynatrace.jira:connection/0/url",
"message": "Name has to be between 1 and 50 characters long",
"parameterLocation": "PAYLOAD_BODY",
"location": null
05 Feb 2025 04:53 PM
Jira for Workflows does not support Webhook URLs. The only supported authentication methods are: Basic Authentication, Personal Access Token, Jira API Token.
All three of those require an URL that looks like this: https://{environment}.atlassian.net (for SaaS) or https://jira.somehost.com (for Jira Data Center / on-prem).
