12 Jan 2024
12:45 PM
15 Jan 2024
08:29 AM
Does Dynatrace is capable of starting or triggering schedulers configured or any script-based processes which might have failed or crashed?
Many thanks,
Srikanth Samraj
12 Jan 2024 12:59 PM
Yes, you can do this with WebHook for integration in the event of an Event or Problem. Alternatively, in the SaaS version you can use Automation Engine for this.
Radek
12 Jan 2024 04:18 PM
Automation engine applicable for Dynatrace managed?
15 Jan 2024 05:47 PM
No, only on SaaS
