Container platforms
Configure on DynaKube-level - oneagent.dynatrace.com/volume-type: "ephemeral"
dyn98007
Helper
This is in the context of configuring node image pull for having  DT code modules image sourced from a Private (Quay) registry
 Is it valid to configure oneagent.dynatrace.com/volume-type: "ephemeral" at the DynaKube-level ?.
apiVersion: dynatrace.com/v1beta4
kind: DynaKube
metadata:
annotations:
feature.dynatrace.com/node-image-pull: "true"
spec:
Julius_Loman
DynaMight Legend
DynaMight Legend
I'd say no. Docs explicitly say this annotation should be set on the application pods.
dyn98007
Helper
You are correct @Julius_Loman  ... It is not a listed (supported) DynaKube feature flag at this time.
https://docs.dynatrace.com/docs/ingest-from/setup-on-k8s/reference/dynakube-feature-flags
