How to get container cpu or memory filter by namespace
Subhash
Visitor
I attempted to add the "Kubernetes Namespace" entity (dt.entity.cloud_application_namespace) for metric configuration, but the implementation is not working as expected.
builtin:containers.cpu.usagePercent:filter(in("dt.entity.container_group_instance",entitySelector("type(container_group_instance),fromRelationship.isCgiOfNamespace(type(CLOUD_APPLICATION_NAMESPACE))"))):splitBy("dt.entity.container_group_instance"):sort(value(auto,descending))
builtin:containers.memory.usagePercent:filter(in("dt.entity.container_group_instance",entitySelector("type(container_group_instance),fromRelationship.isCgiOfNamespace(type(CLOUD_APPLICATION_NAMESPACE))"))):splitBy("dt.entity.container_group_instance"):sort(value(auto,descending))
3 REPLIES 3
p_devulapalli
Leader
@Subhash It could be because below are the only dimensions that are available by default to split the metric
More flexibility would be available via DQL/Grail but unfortunately associated Grail metrics does not seem to be available for these at this time.
You can still be able to query other relevant metrics CPU (Millicore) and split by namespace in DQL if you are interested
timeseries  avg(dt.kubernetes.container.cpu_usage), by:{k8s.namespace.name}
Phani Devulapalli
I am getting No metric found using the Metric Id "dt.kubernetes.container.cpu_usage".
@Subhash That's a DQL query, you would need to run it in a Notebook
Phani Devulapalli
